Volvo 280 A Power reim hums but wont pick up outdrive
kenny nunez
Is there any oil leaking anywhere? Is there oil in the pump? If either of the rams are leaking internally that could also be the cause. If it is a ram problem you will have to buy new ones. I tried to disassemble one with no luck. Volvo does not show a breakdown. However if you do manage to take a ram apart the seals are generic and replaceable. If one of the hoses are leaking they can be copied at a shop that makes hydraulic hoses.
