Re: Volvo 280 raw water pickup leaking.
IN RESPONCE:
1.) THANKS! To all for the input! .... Be advised that I have been SHAMED into trying harder to find and fix the leak before deciding go to a Thru-hull. :redface: Incidentally, I did successfully install a scoop, sea-****, strainer, and jabsco pump years ago to bypass the water pump in an old OMC electric shift. It was an expensive conversion, but it was getting too hard to get electric-shift parts.... the modification worked GREAT in that application.
2.) I have not replaced the hose adapter gasket, it looks good and I can't get water to squirt out anywhere that I can see. Nevertheless, it shall soon be replaced!
3.) All steering bushings etc. feel right, no noticeable slop.
4.) Don's comment about the O-Ring makes sense. The problem DID show up "on the muffs". When the boat was last in the water the cooling worked fine. (I wish I could just put the boat back in the water and call it "fixed"!)
It will be a week or more before I can get back to the project, but I'll post the results when I find the problem. Thanks again!
