Re: Volvo 290 lower unit
Hello: If it is a 1990 then most likely it came from a DPA drive. No problem there though as the remarkable thing about the AQ series is that you can use the lowers through out the AQ line.
Many people make the mistake of calling later models, 290's for some reason. I have even heard some people refer to them as large pin 290's but try and get the right parts when you have a DP-C and and order 290 parts.
Anyways on to your problem.
Glad you ordered a line cutter as it is also used as a thrust washer, some have the washer snapped in and some are designed with it incorporated into it. You should see a hub of a prop and a carrier that is used with out the line cutter / thrust washer. :facepalm:
There is no special model of 290 with a ridge. The line cutter should slide right over and encompass the bearing carrier.
Can you post a picture?
Bill
OH BY THE WAY...
Make sure you shim the lower to the intermediate. The bearing race should have been sent with the used lower unit. If not then purchase a NEW race to insert in the intermediate and SHIM IT ACORDINGLY. You may need another coupler depending on the actual model lower you have
