CapRedbeard
- Joined
- Jun 8, 2021
- 39
Volvo 3.0gspefs
New boater here. Replaced impeller as an add on as I was doing some work on the power steering system. I had the water hoses disconnected and presumably drained some/most of the cooling system as I was working over the course of a few days. Now I can’t get the raw water pump to prime.
What I’ve done so far:
- new impeller (lubed), no water to thermostat
- old impeller (lubed), no water to thermostat
- disconnect inlet hose at thermostat and start engine, no water flow out of the water pump output hose
- press (hard) on muffs to try to force water into system, tried with engine off, on, and water pump disconnected. Water came through water pump hose when engine was off and hose was disconnected.
- flush system from power steering fluid cooler backwards to water intake, good
- flush system from water pump backwards through ps cooler to water intake, good
- flush system from raw water pump outlet through thermostat and engine to exhaust output, good
Im at a loss, any ideas?
