The_Other_Dave
- Joined
- Aug 30, 2012
- 34
I have a '99 Volvo 4.3GL with an SX-M out drive that I purchased
last fall.....used it a couple of times then winterized it and put
it away for the winter.
This spring I pulled the out drive to replace the u-joint bellows, exhaust bellows,
lube the U-joints, check the alignment and inspect the transom bearing and when
I did I found what appears to be the exhaust flapper valves stuck
down in the lower unit exhaust paths. They are burned to a crisp
but I can't find anything else they could be.
(See picture)
They must have passed completely through the y-pipe, the transom
pipe and the exhaust bellows before it got stuck in the down pipes
in the lower unit.
So I did some research here and found Don S's post of the Volvo
tech bulletin that they no longer should be used (see attached PDF)
so I am not going to replace them.
But since I am not pulling them out from the exhaust the way the tech
bulletin shows I didn't have to pull the bolts out to get them out.
So here is my question.....since the flapper valves are (what appears to be) completely
burned off the hinge bolts up in the y-pipe can I just leave the bolts in place
or should I rip the y-pipe out and seal the holes the way the tech bulletin shows?
It seems to me like I can just leave them the way they are.
Interestingly enough the system seems to be quieter than it did before but
I haven't noticed any performance or operating differences.
Any thoughts?
Thanks,
Dave
(See picture)
in the lower unit.
Any thoughts?
Thanks,
Dave
