bjcsc
- Joined
- Jun 1, 2006
- 1,805
Well today I decided to finally winterize, but I was not able to start my engine. I ran my normal procedure, cycled the linkage, left it ~1/4 throttle turn the key and ... nothing. Checked the switch for voltage to and from when in starting position - both OK. Pulled the relay and checked it per the manual - all OK. Checked for current through all breakers - all 3 OK. Checked for battery voltage at starter solenoid (battery cable) - had it. Removed all small wires from starter and reinstalled (no corrosion on any of them). Checked for 12V at small terminal while key in starting position - nothing. Hmmm....hooked up my emergency starter solenoid jumper wires/switch (thanks to Don S.) and the engine cranked but did not start. Checked safety switch - continuous. Cycled the linkage a few more times for fuel, tried the key and it cranked but did not start.
Noticed that the throttle was in neutral position. Moved it back to 1/4 turned the key...nothing. Moved it back to neutral while holding the key in the starting position and it started cranking...moved it back to 1/4 and as soon as it left the neutral detent it stopped cranking. Looked at the back side of the throttle assy, saw a little metal box (seemed to be part of the assy) with a black and red wire. I don't know what that is. I don't have transmission/gears so I would assume there is no shift interrupt.
I'm not sure what to check next...
