Volvo 4.3L one side hotter--with a twist
DaveM
One side of the exhaust on my Volvo Penta 4.3L V6 is hotter than the other. But here is the twist, the risers are fine. It's the exhaust down tub after the riser that gets hot. I should mention that everything is original from 1994 with low hours and fresh water only.<br /><br />I don't know what this means. Is the water pump not pumping? Is the impeller not impelling? Am I off track in left field? Any insightful insights would be greatly appreciated.
SeattleMatt
Re: Volvo 4.3L one side hotter--with a twist
Could be the exhaust elbow. Take the elbows out and "rod" them. basically bang around inside them to release all the rust chunks then spray out with air.<br /><br />Could also be a stuck flapper/exhaust shutter.
Haut Medoc
Is this Lake Washington water,or a closed system? I would look for a restriction in that riser. Just because it has low hours and was run in fresh water doesn't mean it won't rust internally.
Ayuh,.... Plugged Riser/Elbow makes Perfect Sense to Me........
DaveM
Thanks guys,<br /><br />I can believe that some rust might form in the past 11 years of motoring Lk Warshington.<br /><br />Now here is where I proudly show my ignorance... Taking the riser out seems straight forward enough--remove 4 bolts. I assume there are gaskets involved that will need replacing after banging the snot out of it?<br /><br />Don't laugh, it's my first time doing something more than the basics.
There's Plenty of threads covering replacing, or reinstalling Risers........<br /><br />Yes,... You'll need Gaskets,+ Be Careful of the Gasket Faces on the castings...... They Must be Perfectly Smooth.......
DHPMARINE
Never gave this much thought,but do sterndrive engines run even temps on both sides of the block,or suffer from water routing like a say V6 Johnson does ?<br /><br />DHP
On Paper,.... A SBC Should run equal on both sides.............<br /><br />But,.... I've Never Seen It Happen......... ;)
cc lancer
Mine doesn't, facing the engine, the riser on the left side runs warmer than the one on the right.<br />Not a lot, but enough to tell the difference.
