Volvo 5.0 GI low idle
1994almeida
I have a Year 1999 Volvo Penta 5,0 Gi (TBI), with SX Gear, which dies below 1 000 rpm, when cold.
During the start I have to put the throttle a little forward and maintain it in order to reach 1000 rpm or more. When the engine warms he runs properly at idle speed +/- 700 rpm.
As I know on this engine the idle speed is constantly monitored by the Electronic Control Module ECM and controlled by the Idle Air Control Valve. The Idle speed is not adjustable.
Any ideas to identify the cause of this problem?
Thanks, Almeida
Re: Volvo 5.0 GI low idle
Ayuh,....
It sounds like you might want to richen the choke abit.....
Ooops,.... Didn't see the efi part....
Don S
Being an EFI engine, you have 2 ways of dealing with this problem. Either throw parts at it till you fix it, or you get the proper OEM service manual, and start testing after some basic troubleshooting.
Things like loose/corroded connections, changing the fuel filters and checking for water in it, how old are the sparkplugs, cap & rotor, do a compression test etc. after that, it's testing the electronic controls and sensors till you find the bad one.
dcg9381
Thanks, Almeida
As suggested above, you might get a manual and do the troubleshooting diagnostics on the IAC. The IACs don't last forevery, they're essentially a screw that backs itself in and out to adjust air at idle.
If you were going to "throw parts at it" - that's where I'd start.
Other things that can impact it - the temp sensor for the engine itself - internal temp. The ECU needs to know the engine is cold to open the IAC.
Temp sensors aren't very common failures.
Check the timing also.. retarded timing = slower idle.
newport dave
I agree with these guys that it is most likely the IAC, or possibly the ECT sensor, but it could be other things and a service manual would be a big help in making a diagnosis.
Have you checked for trouble codes?
