craze1cars
- Joined
- Dec 26, 2004
- 1,822
1999 Volvo Penta 5.0GL 4110172203
Water pump was dribbling water inside the boat when running. Removed the pump, planning to do an impeller kit. I'm not sure what to do with the bearing/mount plate thingy shown in my attached picture. It spins around freely, as I believe it is supposed to do. However it also wobbles a bit and it grumbles and doesn't spin very smooth and quiet...I assume because it is a completely dry bearing due to water intrusion, along with some wear?
If so, how do I replace this part? I have pulled on it by hand and it doesn't come off...can't see how it's attached. Pressed on? Should I use a gear puller? Will a new one just slip on? Is there a set screw somewhere that I'm missing? Can't find any reference to this part in the service manual, but maybe I'm not reading the right pages. Procedure for replacing water pump simply says "inspect bearing for wear." Then it stops and doesn't tell me what to do if I find wear...
Help please? What part number do I need to buy, if anything, in addition to my waterpump rebuild kit.
Thanks again.
Thanks again.
