Volvo and Onan part number help
mysterym
Was hoping for some help as I embark on an oil, filter, impeller, transmission change on a pair of Volvo D4-300 engines with HS80AE-B transmissions and an Onan MDKBM generator. I have figured out some of the part numbers for the Volvos but need confirmation/help...
Volvo D4-300:
40005013 Oil
22030484 oil filter
22030852 by-pass filter
21718912 fuel filter
3588475 impeller kit? What is part #3583611 “o-ring” for? Do I need? Do these engines have thermostats that need to be replaced too?
Any idea what part # 3581078 is for? Saw it listed on a previous work order.
Part # for air filter? Is it just the “insert” part # 21702999?
Part # for the compressor oil 85108974 ?
Part # for coolant (prefer already mixed, not concentrate)?
Part # for a “spare water in filter sensor”?
Part #s for spare belts?
HS80AE-B transmissions:
Part # for the gearcase/transmission oil? What about part # for filter? It takes ATF?
For the Onan:
Part # for impeller?
Part # for oil filter?
Part # for fuel filter?
Part # for coolant?
Thank you!!!!!
Start with your motor, you said it was a D4-300 but does it have a letter after the 300? In the first link below it contains parts for the D4-300 and other variations. In the upper left corner of the liked page is a search function. If you enter part number like "3581078" it comes back with a listing of all places its used.
Look at any of the links in the page and it will tell you what it is. In this example its a fuel filter
https://www.marinepartseurope.com/en/volvo-penta-cat-47704400.aspx
Continue to look in the above link and find the sections of the motor for your belts and other items.
Here is a link to your transmission HS80AE-B, search in it for the items your looking for
https://www.marinepartseurope.com/en/volvo-penta-explodedview-7748710-44-22390.aspx
Its best to know which Onan generator model you have when looking for parts. Onan is part of Cummins. If you search for Onan marine generator parts there will be several places
QBhoy
Look up the UK site Keyparts. Very popular engine over here and this site will tell you all you need to know. OEM and aftermarket parts.
