jigglestick
- Joined
- May 6, 2007
- 25
for some odd reason I assumed (yes, I know what they say) that I would not need the balast resistor in my new setup, switching from the old 90 horse volvo motor to my aq 130.
I guess why I thought that was that there was none that I could see in the dash panel, harness, or on the engine that.
there is one in the dash in the boat I put the motor in.
question do I need to have this in line in this system?
question #2 where would it fit in the circuit?
my guess is that it goes inline where the hot wire from the ignition goes to the hot side of the coil?
this system has a coil and points ignition.
thank you for your help once again.
I am getting closer to having this baby on the water.
my goal is the 4th of july.
I get the hitch welded on my semi-tractor saturday.
I can then back it into the water and bring it up to temp and try out the drive gears.
I'm starting to get excited
