I have a 1979 Galaxy 19? 6? open bow boat, with a an AQ120B/270 combo,
A couple questions please.
The stern tilt/lift was rammed up through the stern plate, I would assume the previous owner forgot to put in the trailer bracket.
I have found a new stern plate and am preparing to pull the motor/outdrive this winter to replace it, and do some interior and floor work as well.
The motor runs well, and the speedo says she?ll hit 25mph (it only works some of the time)
Although it takes a few minutes for the boat to ?plane out?
Are there any easy ways to get more power from the motor?
(fuel injection,forced induction, etc?) or should I consider a motor swap since I will have it out?
Is there a retro fit power trim/tilt system for the 270 outdrives?
Or could I fabricate one using Mercruiser or OMC parts?
My friend has a Mercruiser outdrive and the tilt cylinders appear pretty simple, I believe I could fabricate brackets to mount on my outdrive.
I like the size of this boat, (fit?s my family well, and rides well in the water)
I am a welder by trade and have a mill/lathe at my disposal, so I can fabricate and weld aluminum.
Thank you for any tips/advice in advance,
Andy
Andy
