I have a Volvo AQ125/270 on an '85 Capri. The rubber bellows broke between the exhaust manifold and the tube that goes to the outdrive. When I went to replace the two tubes do not line up by over an inch. When I look at the front of the engine the FW cooling tank is not level, nor is the carburetor. It appears the whole engine is listing to the starboard by 10-15 degrees. Has anyone heard of this? How do you adjust the alignment of the engine?
Thanks
Thanks
