volvo aq125a engine overheating
hello folks,i had rescently took the head off my 4 cyl and had it machined,changed all of the gasketsput new timing belt on.<br />my question is why does my volvo over heat during 20 -30 mph and what causes it to not want to start while it is hot?
akriverrat
Re: volvo aq125a engine overheating
timing advanced to much? does it not want to crank when it is hot?
nikk
hello does it sit at 140-160 then when you go up to full trottle is it at 195-205 if so i was told its normal for a volvo fresh water/closed cooling termostat starts opening at 198 and stays open let me know what your temp is :rolleyes: maybe im wrong ?????
rsfeller
temp should get much above 180-190 with this engine...
On my manuel is says it should open up at 180-198 but it gets up too 230 240 then i shut her down and wait til she is cool again.the thermostat does open at 180 and holds steady until she in the water and under its own load. i do believe it needs timed with a gun ..thanks for the advise what do u think i should time it at?<br />i have no expirience with a timing light im used to listing to a car but as we all know this is a boat instead lol..
