In my workshop manual the wiring diagram for my AQ130 shows only one wire from the ignition switch, through a ballast resistor to the coil.
Should there not be two wires? One from the run position on the switch, through the ballast resistor and to the coil feeding 9v for running, then another from the start position on the switch directly to the coil feeding 12v for easier starting?
Thanks,
Louis
Thanks,
Louis
