Hi all,
I am running an AQ170 VP in a 20ft Bertram. I bought the boat with a "rebuilt engine" that had not been water tested. I have had the engine apart to sort out a leaky rear main seal and believe it to have been be rebuilt. The boat has now been run but I can not seem to get the timing right. If I set the timing to the standard 15deg BTD at 2000rpm the engine starts to detonate from about 2000rpm upwards under load. I can retard the timing and get it to run up to 4800rpm with very slight pinging but the timing is way out for this to happen. 28 deg and -2 deg at idle.
The dizzy is the mechanical advance with no vaccuum adv.
Could spring tension on the advance weight being too loose cause this do you think?
Thanks
Sean
Thanks
Sean
