volvo bellhousing questions
lilmandavis
I have aquired a sbc 350 gen 2. I have a boat with an old style 280. A 12 3/4 flywheel is what is in it. as far as i can tell there isnt goin to be enough room for a 14'' flywheel in that housing. I remember the dimensions from a ways back when i put in bell housing bearings and seals. Question is will the 14'' fit in that housing or am i looking at way to much money and should stop while i am ahead. THe sbc has only the offset starter holes drilled into the block and im sure i would have to go with a marine sealed mini starter beacause of the nose cone would bottom out before being able to bolt up. right?
OK hack me away !! - thanks
Don S
Re: volvo bellhousing questions
You're going to need the newer style bellhousing. The 14" flywheel will not go inside the bellhousing.
jerryjerry05
Why are you trying to change? Trying to find the right one is tricky at least.
The Volvo used a GM flywheel that was used on v-6 motors.I had the part number but can't find it anywhere. That block was a light duty motor with a different crank.The flywheel on it wouldn't cross over to most blocks.
I had to go to a GM dealer and match it to the short blocks I replaced.
Thoes light duty sucked a lot of valves.Jerry
lilmandavis
would you by chance have a housing part number don?
Don S
The link below will give you the numbers for the individual parts. Note item 12, will be a bearing or a bushing that goes into the end of the crankshaft. Without it, you will destroy the flexplate and probably the new bellhousing.
Hopefully ole f...nscreename sees this thread, he ordered the same thing as a kit, but not sure from where or what the number was. But you need the same thing.
http://www.volvopentastore.com/DP_F...*****.992096048--store_id.366--view_id.311949
lilmandavis
Don.... You have helped me and everyone out numerous times. ON everyones behalf... Thank You very much for all your time and effort here.
And to everyone else that makes I-Boats THE BEST boat forum around. Thanks to you as well....
Thanks I-Boats!!!
lilmandavis
Would a new style starter work then to? Or would I still have to go with the mini starter?
