Volvo compatability
swcejk2002
Hello again forum. I have an 83 Bayliner Explorer. It has a volvo 270 drive on it. It doesn't appear to be in the greatest shape. I came across a 280 from another boat (seems to be in great shape). Can I use the 280 on the boat?
The 280 has a serial number that I have been unsuccessful in researching.
PZNR 2820059C, any suggestions?
Gene70
Re: Volvo compatability
A 280 has a different upper gear housing and probably has different power steering. The 270 has mechanical tilt. Would be quite involved to change over. call me and I will discuss it with you.
Don S
The only thing that will be different between the 270 and 280 is the clamp ring on the upper gear box. Different mount screw for the helmet. Changing it is a lot easier said than done however. The clamp ring is interchangable between the 270 and 280 if in good shape. A job for a qualified tech to reshim the double bearing box, for proper backlash.
