Volvo diesel D4 260 Inboard
Anchor24
On a Volvo Diesel D4 260 I must change the racor (fuel water separator). Does anyone know which model racor is needed? Is it 500? 900? 1000?
Thank you
Anchor24
Howdy dead weight to hold boat in water (Anchor) :D sorry had to do it
Look on the side of the filter (which you may have done this) and see if there is any model number on it
Anchor24
thank you supreme mariner i do not think the racor was replaced when engine was replaced i read diff size racor diff flow rate of fuel trying to find what gpm engine calls for 1gpm 1.5 gpm 2gpm thank you!
The Volvo spec shows the motor to use a bit over 50 gph of fuel at max load and rpm, so the 1 gpm should be good. If you plan to run it at WOT for long periods of time you might need to change the filter more often. Good thing about a diesel, if the filter started getting clogged it would just loose some power, and come right back after the filter was replaced
http://www.volvopenta.com/volvopent...lEngines/diesel-centro/Documents/D4-260 I.pdf
bigbrownbuku
Three different styles with 3 different filtration rates. 500/900/1000 amd 2010/2020/2040 and brown(2micron)blue(10 micron) and red(30 micron)
