Volvo Diesel Engine oil drain?
Jayrock
I have a Volvo AQAD40B straight six diesel in a Blackman that I recently purchased. Iam a pretty good with mechanical things, but I cant seem to find the Plug or fitting to drain the engine oil. Is it one of the motors that you have to pump the old oil out of? Thanks in advance for any insight, Jason
Re: Volvo Diesel Engine oil drain?
Ayuh,... I donno, but would assume so... I'll bump this back to the top for ya...
Don S
Close to the dipstick tube on sticking up between the arms of the manifold should be a tube with a plastic cap on it for sucking the oiil out. Just warm the engine, and hook a hose onto it, (NOT in it). The tube goes to the bottom of the pan.
Jayrock
Thank you. I found it the tube.
