john lyons
- Joined
- Jul 3, 2010
- 14
I have a 1979 Glas Ply boat with a Volvo Penta140A that I cannot get to
consistently rev above 3500 rpm.
I have done the following:
changed the plugs and plug wires, put on a new distributor cap, checked the
timing, checked the coil by seeing if it gets hot when running the motor (it
does'nt, put an in line fuel filter, the points looked good, checked the gas tank vent line to see if it was plugged (it was not) ran the boat with the
gas tank filler cap open, and had the carburetors rebuilt by a shop.
The boat sometimes will rev up to 5200 rpm and run fine but most of the
time it will only rev 3500 to 3800. Sometimes it misses other times it runs
smoothly but will not rev beyond 3500. The boat temp normally around 190.
Does anyone have experience or advice concerning about this problem?
Thanks for any help.
Montana Boater
Montana Boater
