Volvo Penta 2003 SX Drive Oil?
baker556
Hi guys,
What's the expected oil to be used in the outdrive of a VP 3.0 SX drive?
Would it matter using something other than Volvo's own oil?
Also would anyone happen to have the rubber o-ring part numbers for replacement on the dipstick and the drain plug? OR make use of a universal O-Ring should do the trick?
Thanks
saaristo
You need three O-rings. One for dipstick, one for overfill and one for drai. Part numbers should be 3855081 and 3852045. Thats what I have on the packages.
jimmbo
Hi guys,
From the VP Operator Manual:
The drive unit is filled at the factory with Volvo Penta DuraPlus
GL5 Synthetic gearcase lubricant. This lubricant must be used
when adding lubricant or refilling the drive unit.
The "Must" part is that it must be a Synthetic GL5 Oil. Using anything Else could lead to Failure of the Drive Train. Something to do with Oil-Bearing Material, compatibility
dubs283
The sierra brand gl5 rated gear oil is used in almost every boat repair shop across the country for Volvo drives
dypcdiver
Until about 2010 Volvo used to recommend Mobilube 1 SHC 75W-90 until they realised that they were missing out on selling their overpriced own labelled stuff.
I also use it in gear boxes and transfer cases in my Toyota Landcruiser and Rav4, so buy it in 20ltr drums.
jimmbo
Never heard of that. In 2002 Volvo was recommending their Brand of Lubricants.
dypcdiver
From VPA 7743008 07-2003
Sterndrive Oil Capacity
Draining and Filling Sterndrive When a complete change of lubricant is required in the sterndrive,
proceed as follows:
1. Remove both propellers See “Propeller Removal and Installation
- DP-S Models” on page 263.
2. Place sterndrive in the run (full down) position. Place a
4 quart drain pan under lower gear case skeg to catch oil.
3. Remove the oil drain plug (inside lower gear case) and the oil level
dipstick (top of sterndrive). Removing dipstick vents drive to
improve oil draining. Allow oil to drain completely.
34086
33836
Change Lubricant Every 100 Hours
or
Once Each Season Use
Volvo Penta Synthetic Gearcase Lubricant
or
Mobilube 1 SHC Fully Synthetic SAE 75W-90
gear lubricant
All DP-S Models 81 oz. (240
I have been running Amsoil ( currently $13/qt) for years
baker556
Thanks all,
So effectively I'm looking at any oil that has the following:
75w-90
Fully synthetic
GL-5
I've looked for the amsoil but a little difficult and expensive to get hold of here in the UK, I'll probably grab the Mobilube 1 SHC 75W-90.
Can anyone recall the amount required to fill the drive?
Thanks for the O-ring part numbers massive help!
dypcdiver
From the manual
Sterndrive Oil Capacity 71 oz. (2100 cc)
BTW I generally buy my Mobilube 1 SHC Fully Synthetic SAE 75W-90 from Ebay and usually comes from Germany (make sure it is SHC as the others are LSD axles.
baker556
From the manual
Thanks - that's 2.1 litres just over the two mark, how annoying! :D
Three litres of Mobilube 1 SHC Fully Synthetic SAE 75W-90 from ebay it is, thanks again.
baker556
Thanks cptbill.
Another to add to the list.
I'd assume anything that is SHC GL-5 75w-90 is acceptable.
Agree to change this every year on the drive unit no matter the hours, its not worth the risk.
Thanks
