Doug-ole-waterdog
- Joined
- Aug 15, 2009
- 14
Hello, I this is my first thread. Been reading, but none of the articles answered my issue.
I had the boat at the lake a week ago and it ran pretty good for about 45 min. 30-32 MPH. That was when I had the 0* BTDC and 38* dwell. It ran a bit warm 200* I slowed down like to pick up a skier and let it idle for a few min. Then shut it off for about 5 min. Started it up and all the problems came back.
I have new battery, fuel pump, distributor cap, points, condensor & plugs. I have cleaned solex carb on engine. Junk on screen in accel pump and in all jets. Cleaned out passages and Accel pump. I have ran w/muffs on two gallon can to eliminate tank. No difference. Tank is plastic. Blew through vent hose and pushed gas out of tank. Sucked through pick up hose and got all fuel. Disconnected fuel pump line at carb and plenty of fuel going to carb. Accel pump steam through candy cane is strong. Disconnected linkage and opperated throttle by hand and watched fuel in barrel looked good fuel coming out of center post at all holes. Nothing comes out of the tube from the bowl, but tube is clear.
Engine will only start @6*BTDC if dwell is at 35-42*. If I set dwell at 62-63 engine will not start unless 0*BTDC or less. I can start engine on either setting on muffs and can idle up RPMS slowly. If I try a rapid accel I get a backfire with flames out of the carb.
I had the engine running with no back fire @ -2*BTDC (hard to see behind pulley) and dwell at 38* took it to lake and under load pops and no power.
I keep cleaning carb each time and trying to set Dwell @62-63 and 6*BTDC like it says on the engine and on other threads and I can't get there.
Any help is appreciated Doug
