Volvo Penta 280 more power 5.7
elahuta
Hi guys, what motor mods can I do to get more out of my 1988 Volvo Penta 280, 5.7 to make that thing go (Heads, Cam, Intake, Carb, Super Charger, Nos etc....)
captmello
Re: Volvo Penta 280 more power 5.7
there are a couple things but your not going to double your HP.
What boat are you pushing with that engine?
mkast
How fa$t do you want to go?
P 0 P E Y E
Before you bolt on parts, Make sure the engine is all there, RPM, compression and fuel.......
elahuta
The motor was just rebuilt and I just did a compression check and everything is good.
So, what options do I have in upgrades on the motor???
Thanks
captmello
Thanks
You could upgrade to vortec heads, you'd need to change the intake manifold as well. that would gain you 30 HP. I assume you already have a 4 barrel carb.
I don't know anything about Nos, supercharger, etc. May as well buy a different boat.
slasmith1
With that hull more HP will not translate to much more speed. It is not like a car where the rolling resistance is not a limiting factor your hull limits your max speed by the amount of drag you create with contact with the water. All you will accomplish is spending a lot of mony so that you can burn a lot more fuel.
Ayuh,... You've got your Cart ahead of your Horse,....
You should have been asking that question Before it was rebuilt,...
Unless you're planning to do it Again...
Save your money,+ find a BBC/ Bravo....
robjen1019
I was going to say that, should have had it stroked when it was rebuilt.
elahuta
What type of vortec heads? (Cast, Steel, Aluminum) I curently have 1988 heads with pressed in studs.
Can I run Aluminum Heads? I have an heat exchanger running coolant.
Also, I have a set of 1963 camel hump 2 heads with 202-196 valves rebuilt sitting on my race motor never used with all of the goodies. I know I will have to change the springs.
With the stock cam can I change the rocker duration (it just give me more lift without changing the cam duration)? Or is that a no-no...
Thanks
