volvo penta 290 outdricve hinge pins stuck
sme5
I am trying to remove my penta 290 outdrive I took the bolts out of the pin and have been spraying with a lubricant for days and still can not get pins out. I am reading use a slide hammer puller. is this a reasonable attempt and has anyone found an easier way to do this or any tricks. thank you for any feedback.
K-2
I made a simple puller, all thread and a piece of pipe. Cheap & easy to make.
1/4" all thread, screw the all thread into and through the pin, with just enough sticking through to get a nut and flat washer on.
Flat washer must be smaller diameter than pivot pin so washer will go "out" the hole with the pin.
So now you have all thread sticking out of the hinge on the outside , place a short length of pipe over all thread, the pipe must
have a large enough ID so the pin will fit inside pipe. Then a flat washer over end of pipe, washer must be big enough to NOT
fit inside pipe. Then a nut. Tighten outer nut and it will suck the pivot pin up into the piece of pipe.
Does that make sense? Do you understand it? I am HORRIBLE at explaining things with a keyboard! :)
If the pin doesn't pull out then you can try heating it up with a torch. Heat the housing around the pin, don't direct the heat
right at the pin itself. Cast aluminum expands nicely when heated.
the slide hammer works ok. I have even made a puller. however if they do not move initially, use a brass hammer and drive them in a bit. if they continue to be difficult, you can use a 5# maul and a brass punch and simply drive them in all the way. just turn the outdrive a bit for clearance (at the helmet).
corrosion is a biotch.
when you put it back together, pick up some teff gell to prevent the issue.
sme5
Got pins out had to drive them through with a piece of brass. Thanks guys
