Volvo Penta 350 noise with key off !!!
Scubasteve87
hey guys I've got a 25' skipjack with a 350 penta and the 280 outdrive. I was cruising at 3500rpm when my anchor came loose and started paying out line that I was going to run over and foul. I did an emergency stop, I.E. I slammed it back into neutral, (possible hit a touch of reverse, but not much). The engine quit as I keyed it off. When I went to restart it:
A sound that I can only describe as a coffee grinder (or some kind of electric motor spinning at high RPM)
I switched it to Key OFF
The noise continued...until I switched battery selector switch to OFF
I switched the battery ON to see if the starter was running away, but that did not seem to be the case...and I still couldn't find the cause of the noise.
Turned everything OFF and I let the situation sit for half an hour to cool off for good measure.
Turned battery ON, noise continued, tried to start a few times(normally it starts on first turn). Then the noise stopped, and I hit the key again and it started. Idled great, ran great all the way straight home:) Any ideas as to what that noise was? I'm pretty new to this boat, and inboard engines, but no stranger to turning wrenches on cars. All I can say is that the noise sounded mechanically bad.
