whitebunnyflock
- Joined
- Jul 12, 2017
- 64
got alot of maintenance done on the leg thanks to you guys, really appreciate all the help
Now another problem. Had a heck of a time getting it to start yesterday when i was running through fuel stabilizer and heating my motor oil. I had removed the flame arrestor in order to fog it. I didn't really see gas coming down into the carb and so i poured some fuel directly down into the throttle body. That did not get it going. It seemed like it wanted to go and would "run" so long as i held the key in the starting position. Finally we held down the flap that you see in the throttle body when you first remove the flame arrestor and it fired right up. I noticed the flap is controlled by some sort of electronic device and i wonder if there is a problem with that in particular?
The other thing that could be a problem is that this boat appears to have an inline fuel filter as well as a filter that mounts under the fuel pump. I have replaced the one that mounts under the fuel pump but can't seem to find any parts online for the inline fuel filter.
It had this problem towards the end of the boating season but always seemed to be able to get it running eventually. Also once it is warmed up there is no problem starting and running.
Any help you guys provide is much appreciated. It is now winterized and so won't be running it until spring anyways but thought maybe there is something i could do this fall to figure the problem out.
