Trying to locate a problem. My motor seemed to start fine when first put in the water. For a few minutes anyhow. While warming up it would die and be very difficult to start. Once started and underway everything runs normally (oil pressure and RPM). I stopped suddenly and the motor stalled. Would not restart. Checked the fuel and its getting fuel. Fuel pump has pressure. Gas was drained two weeks ago and new gas on this trip. Checked the plugs. Burn looks good has spark doesn't appear to be flooded. Removed all plugs and cranked checking for water and none present. Cranked for a bit and noticed a puff of smoke back up through the carb. Have fuel spark compression and no water. Any ideas what to check next?
