Volvo Penta 5.0 GL V8 Overheated -Help plse
whatmot
I have a 1998 Reinell 197 with a Volvo Penta 5.0 GL stern drive. I recently purchased this boat after it was sitting unused for a year.<br />I went out for a test cruise and noticed the engine temp was running hot (190-200f) at about 3600rpm's. After about 20 mins cruising the engine lost power and stalled. There was a burning smell and the engine would not even crank over.<br /><br />Before launching I had checked fluid levels (oil, transmission fluid, etc) and ran idle on the hose to make sure water was passing thru the engine.<br />I think it might be an impeller but really no idea?<br /> :(
Limited-Time
Re: Volvo Penta 5.0 GL V8 Overheated -Help plse
Will the starter turn the engine over or does it appear to be seized? Did you notice the oil pressure before the engine stalled?
whatmot
Thanks for the response. <br />I brought the workshop manual for the volvo penta stern drive and diagnosed the problem myself. Turned out to be a number of issues...<br />1. throttle was jammed open. spray of liquid screwdriver repaired this.<br />2. Spark plugs were worn out - little spark.<br />3. Impeller needed replacement to prevent over-heating.<br />Thanks again
