Re: Volvo Penta 5.0 ?
I stuck a GMC 350 Vortec out of a mid 90s pickup in mine. Then it turned out my shortblock was fine, so my buddy put that in his 98 Chevy truck, so yep, its the same. Any GM truck with a V8 in the mid 90s will work. Vans are the best because they are extremely cheap. For some reason pickups and SUVs bring more money. 305 and 350 are the same dimensions on the outside, so no problem there. You will likely need to use your camshaft from the boat engine. I had a problem with the cam endplate not fitting, but found one at a local auto parts store.
Not entirely sure you are going to find a decent truck engine for less than you can find a remanned boat engine. All the ones I found had a ton of miles and were top dollar. In the end, I found a rebuilt shortblock, then bought a set of heads off ebay. Cost me way more in the end than if I had just used one of the online venders and bought a remanned boat engine. Plus i would have had a warranty.
