HawaiianHooker
- Joined
- Aug 23, 2005
- 41
Hi All,
I have a 99 Striper boat with a Hi All,
I have a 99 Striper boat with a Volovo Penta 5.7GSI-PWTR that just wont start, cranks and cranks and sometimes tries to start.
Compression is 88lbs on the low, 120lbs on the high
Spark is there but seems kind of weak.
I've replaced the battery with a new one.
I've replaced the high pressure fuel pump, tried starting fluid and no difference.
I've replaced the electronic module under the distributor cap, no diff although its the auto equivalent.
Still won't start....
Prior to all of this the waterpump seal went out and sea water sprayed off the belts and all over the motor, I've since checked all connectors, wires etc and cleaned and coated with dialectric grease.
Any suggestions? ideas? too low compression? too weak spark?
Thanks,
---Mike 5.7GSI-PWTR that just wont start, cranks and cranks and sometimes tries to start.
Thanks,
---Mike
Thanks,
Thanks,
---Mike
