I have an engine on a standalone tank and on a pallet I have running on non ethanol. I've changed out the fuel pump since it was shot to a Chinese one just to get it running. It cranks up and runs but misfires. It has all new spark plugs. The previous owner changed out the fuel rail and the fuel pressure regulator. Fuel pressure regulator was not clogged when I pulled it.
I already pulled the fuel rail and primed the fuel system and I let it sit and did not see any fuel pool on the injectors. All the spark plugs I pulled were black with soot aside from one on cylinder 3 or 5, it was clean. They all reeked of old fuel when I was cranking the engine with the old fuel pump on it.
Any ideas/suggestions on how to check the fuel injectors or what else to check? I have a plug cut off from another harness and I was going to put 12V to it and blast some brake cleaner through them to check if they are clogged.
This engines been stored inside the entire time shrink wrapped on a pallet after being pulled. They winterized it but forgot to run treated non ethanol fuel and drain the fuel pump. Hence the need to replace the old one.
Here's the part number on these injectors. 0280158165
