shackmaninc
- Joined
- Sep 29, 2010
- 27
Hello all I need some advice.
I recently replaced my head gaskets on a fairly new engine rebuild (20 hrs.) The port side head gasket was blown. Middle two cylinders were blown and eating coolant. Closed loop cooling system btw.
Upon start and test run today with a new thermostat 160 degree. I had my heat gun at the ready everything was just dandy manifolds were both at about 140-160 and both heads were at the same 140-160 (a bit colder at the rear of the engine) and the block at 140ish. My worries are with the intake manifold. Both front and rear of the manifold were about 130 -140 but right in the middle where it looks like there are another set of ports the temperature was a blazing 300 at the end of my 10 minute test run. I was running the engine on muffs and was at idle for 5 min. and then up at about 1500rpm for the last five.
I really can't recall if those are water ports or not, but I just don't feel it should be that high. The paint even has been burnt off right on those ports. I am thinking that maybe this has something to do with the head gasket failing right in between those two cylinders.
I would appreciate any help or input you guys have. I just don't want to go out and have the same thing happen if it is something that is bad.
Thanks for your help
