Volvo Penta 7.4gl 1995 Water in Oil
Kyledv66
Hey guys,
Looking for some pointers here.
I have a 1995 Volvo Penta 7.4GL (454) raw water cooled engine that has experienced oil in the water. Have been running the engine off a hose, and noticed the oil to be a white milkshake. Ran the engine a little hot, white steam came out of the exhaust, and the color of the oil darkened. I gave it an oil change thinking it was some condensation left over since it has been sitting for a while, but the water milkshake returned.
I started thinking leaking exhaust manifold/risers, but when I took those off and tested them with water, nothing leaked back into the exhaust ports.
I started thinking that it was a blown head gasket and began taking the engine apart. On first glance the gaskets for the intake manifold were really bad, and crunchy. I thought maybe this could be the reason for the leaking but I figured I'd just replace the head gaskets since im taking the engine apart. I then discovered the intake manifold had a hole in it, starboard side on the middle port (I think its air intake from the carb?). I bought a new iron intake manifold to fix this issue.
I then started taking off the heads, checked the valve for leaks by filling the intake and exhaust ports with water and waiting for some leaks. A couple of them did have some leaks (probably some bad compression going on), so I did a valve refresh with some valve grinding compound, checked for leaks and all is good.
The head gaskets seem to be in good condition, they're not corroded or cracked. I did notice some slight surface rust on a couple of the cylinder walls. Could that be indicative of water in the cylinder?
Anything else I should be looking for before putting everything back together? I'm in San Diego, CA, so no temperatures below freezing. Boat has been stored on a trailer. I would hope that the block is not cracked. Any tips or advice on what I can do would be greatly appreciated.
Thank you
Using water to find leaks is not a good method, using acetone would be better. Water is thick and needs a larger opening to pass
The exhaust mans should use air pressure or acetone, just don't have plastic and rubber parts from making contact
Water in cylinders is a leak from a gasket or engine part (intake, exhaust mans, head or intake gasket)
post a pic of the manifolds. however if you suspect them, simply change them and the riser. especially if the boat ever saw salt water
agree with AD, use acetone to check for leaks
tpenfield
:welcome: to iBoats . . .
You did not mention the gasket between the manifold and the risers . . . usually the first thing to leak.
Usually, when water is found in the oil, a cooling system pressure test is in order to locate the source of the leak. Taking the engine apart pre-maturely defeats that, as you will be mostly guessing as to the actual cause (as you were doing).
Tell us (post a picture) of the 'hole' in the intake manifold . . .
Also tell us a bit of history on the boat/engine. More info is better than less. :thumb:
Lou C
https://www.crowleymarine.com/johnso...arts/53969.cfm
http://www.volvopentastore.com/Lubri...view_id.778967
I think some of these engines had an engine oil cooler, here is a pic of the OMC version, which is identical to the Volvo you have (I used the OMC parts catalog because if you don't know the Volvo model # their catalog is hard to navigate, but here it is, same part same part number NLA from OMC but Volvo still lists it as available) if this cooler leaks it will put raw water into the motor oil and would have been the first thing I checked!
Next, exhaust, then intake manifold and cyl heads.
After the oil cooler.....
If you had water in the oil and the cyls, yes it could be the exhaust esp the elbow gaskets...
If you have water in the oil but not in the cyls, the exhaust is not a likely culprit, possible though...
Other causes are a leaky intake gasket, this will put water in the cam valley, and head gaskets these will put water in the motor oil or in the cyls or both, depending on how they are blown. Other more expensive causes are a cracked head, block or a rotted intake manifold.
Before taking it part I agree there are cooling system pressure tests that would reveal leakage, I also rigged up a dynamic test on my old engine to see if combustion gases were getting in the cooling water and sure enough they were. I had water in a cyl and water in the oil and the exhaust passed the acetone test.
I wound up having the heads checked at a machine shop and the outcome was that exhaust valve seats were cracked on both heads in the center cyls (prob from an overheat 3 years before the head gaskets finally blew). The water in the cyl and oil was clearly from the blown HGs.
The cure was installing a set of re-man heads with Fel/Pro head gaskets and new ARP head and manifold bolts.
In your case I might get the heads checked out by a good machine shop and re-assemble with a Fel/Pro top end Marine gasket set, you may want to replace the head bolts depending on what condition they are in.
If you are in salt water, you may need to get a set of re-man heads because those could be close to rotting through, behind the exhaust valve seats, have the machine shop check that carefully if it was used in salt all that time. On my heads the cooling passages were eroded from salt use and even if they were not cracked, the machine shop felt that they would not seal right after being re-surfaced so for that reason and the cracks, I replaced with re-man heads.
If used in fresh water you may just need a basic freshening up of the heads.
If the exhaust looks good (only if used in fresh water if in salt they need to be changed every 5-7 years) it can be acetone tested and for sure if you have an engine oil cooler, get it tested!
Kyledv66
Hey guys,
Thank you for the great tips. Ill make sure to give the acetone test a try with what I've done so far. To go off of what Lou was saying, I did check out the oil engine cooler (with pressurized water, around 20 psi), maybe I should go back and try with acetone. I'll make sure to report back with photos of the intake manifold hole, alongside photos of the exhaust manifolds and elbows.
As far as info on the boat and engine, I bought it as a fixer upper for almost free. Its a 28ft Larson 1995 with a 7.4GL Volvo Penta 454. It was running when I purchased it. No water in oil at time of purchase. As far as what I've seen, the engine has about 780 hours (according to hour meter, seems to be original factory Faria gauge, but I don't know if it was switched out). The boat spent some time in the ocean, has bottom paint on it, but other than that it has spent many years in storage on a trailer.
Lou C
I don't think I'd run acetone thru the oil cooler, if it does not leak at 20 psi its probably fine because there is very little pressure in a raw water cooled cooling system.
So it was used in salt water, has your use continued that? If so then really get the cyl heads checked out, and check the mating surfaces of the cyl heads where the intake mates to them, in the front at the the water passages. I think the Fel/Pro marine gaskets are superior to the OE gaskets. Acetone test is good for the exhaust manifolds. I used to change mine every 5-7 years and never had water in the engine from the exhaust and this boat was in 100% salt water on a salt water mooring, 6 months out of the year for 15 years. The hole in the intake, was that in the center exhaust cross over passage? These and the small block Chevrolets used an exhaust cross over to heat the spring for the auto choke and also to keep the carb from icing in cold damp weather. This was done away with when they converted to Vortec heads, so the intakes are totally different from pre-vortec (what I have and you have likely) and Vortec. However water from an intake will usually be from a hole rotted right under the thermostat housing, or leaky intake gaskets at the front water transfer ports that let hot water out of the cyl heads and out through the thermostat housing.
post up some pix we love pix!
Lou C
some pix from my top end overhaul....
Kyledv66
Alright, here are some pics of the intake manifold hole. Pretty big. I went ahead and bought a new one.
Also attached are the condition of the intake gaskets, head gaskets. The intake ones look a little rough.
Kyledv66
Here is the condition of the heads when I opened them up (very rusty!), also with my little leak test with water (which I will repeat with acetone). I have cleaned up the carbon off the valves, and will get to cleaning the carbon off the cylinder heads too.
I'll be posting the exhaust manifold elbows later.
Does look like it was the intake and gasket
Its not the oil cooler, the oil pressure is at least 10 psi idle and 40 psi running. Water pressure is a 5 psi idle and 30 psi running. If oil cooler had a leak the oil would be pushed out into the exhaust water and would run dry
To test an oil cooler I would use air at 60 psi on the oil side
Lou C
That hole is not in a water passage but the intake gaskets look very suspicious and could be your source of water, did you have water only in the oil and not in the cyls? Were any of the fire rings for the head gasket burned through? It will look like a slit on the side and can let water in a cyl and in the oil...
Lou C
It does look like you had some water in one of the cyls, not a lot but some in the one on the left hand side of that pic, is it the rear cyl #8? It will be interesting to see what your manifolds and elbows look like. That hole in the intake is curious. I'm not familiar with the big block only having had the small block V6 but it makes me wonder how it rusted/burned through there....
I am still running the 32 year old one on mine, and at least half that time it has been in salt water....
Also compared to how my engine looked yours appears to have more rust in the cam valley area, which would suggest the intake gaskets were leaking, but once water gets in the oil it tends to spread around and you can find evidence of it in areas far from the source. I was surprised that I had very little corrosion anywhere really even though it was salt water, for approx. a week or so, till I figured out what was happening and drained it after every time I ran it.
Kyledv66
Thank you for the responses guys, really appreciate it.
Attached I have the exhaust manifolds and the elbows. The gaskets ripped up as soon as I took the elbows off. I haven't cleaned then up properly yet. There's definitely some rust inside the water jackets, but I still need to confirm with acetone if they are the source of the leaking.
And Lou that is cylinder 8, there wasn't any water inside when I opened it, but there is some rust there. Gotta pop off the starboard side and check those cylinders.
Lou C
They don't look bad but you really can't tell till the sealing surfaces are cleaned up and you test the manifolds with acetone. If they are good you could re-use them but install new elbows and gaskets.
Lou C
A couple of other things I noticed...
has this engine ever been apart? I saw an '.040' stamp on one of the pistons suggesting it may be a reman engine...
for a raw water cooled engine there is not much rust at all in the cooling ports, mostly black carbon it looks like, wonder if somehow oil was als getting into the cooling water, usually on an engine used in salt you see a lot of rust build up in the block and cyl head cooling passages, in fresh water some light surface rust. I don't see that much there unless its under that black/carbon looking coating...
the rusty deposits in the cam valley and round the hydraulic lifters look like they have been there a long time...
your exhaust manifolds and elbows, were there any rust trails emanating from the joint between the 2 where the gasket is? I don't really see evidence from the pix of water stains/rust inside the center exhaust gas passage.
Kyledv66
Hey Lou, thanks for the suggestions. All the water passages are filled with thick carbon. It chips away with a flathead screwdriver. I ended up shopvac-ing as much as I could and chipped away as much as I can, but still no rust present in water jackets.
I did the leak test with acetone. Plugged it up and filled from the top and let it sit there all day, and not a single leak. The liquid line stayed the same and I couldn't find any wet spots on both exhaust manifolds. I did however find some rust inside in some areas of the exhaust manifold, almost as if suggesting water passed through. But mostly black carbon. The gaskets between the riser and manifold looked clean, no rust. The water jackets of the exhaust manifolds and risers on both sides are a bit rusty.
Side note, I ended up finding a busted spring on my starboard side, 5th cylinder intake valve. Not sure if this is related to the whole water scenario, but maybe water was in the cylinder and broke the spring.
I'm just not sure if I should drop a few hundreds to replace all manifolds and risers since they're not leaking now.
I'm really wondering if the intake manifold gaskets we're to blame for all this mess, because the gaskets themselves were rusty, crunchy and deteriorated. Rust everywhere on the intake manifold to the point where a hole rusted through. Maybe the water was leaking into the cam valley and that's the source of the milkshake. I don't know, what do you guys think?
Lou C
Salt or fresh water use? If they pass the acetone test and the sealing surfaces clean up well and are flat to less than .003” then you could use them. The rust you see could be condensation since these probably run pretty cool. I would get the heads checked out by an automotive machine shop esp if used in salt water.
Kyledv66
Yes the engine has been used for saltwater. Surfaces cleaned up pretty good for the exhaust manifold and riser. Ill keep ya guys posted on the work being done. I think i'll check out the heads next. Otherwise i'm pretty much ready to throw everything together with fresh gaskets and hope for the best.
Lou C
When you take the heads to the machine shop make sure to tell them that they were from a boat used in salt water and look for corrosion in the water passages, because it is possible for them to rust through near the valve seats and that would let water in a cyl and hydrolock the engine, NO GOOD! Judging on the condition of your block and exhaust manifolds they maybe fine, might just need a freshening up.
