Hello all,
I just bought a really nice old boat, an 18 foot open bow Imperial with a AQ131D engine. I know the old Imperials don't get much love but I had a 21 foot with a Merc for years and loved it. Never left me stranded in the middle of the lake. I live in Michigan and the boat has only even been in fresh water. The previous owner was the second owner and his dad was the original owner. I don't have a bunch of history as the dad passed away and the son only owned it for a year or so. It was stored inside.
The issue I'm having is just idling of even cruising around at 2200 rpm it stays around 180 degrees, when I get it up on plane it heats up pretty quickly to 220, and once I kept on it to see if it would keep going up and it did, close to 240. It never boiled over, I backed off before that. When I drop back down to 2000 rpm it cools back down in a minute or two. When I turn the engine off when it is on the hotter side it diesels before stopping so I know it is hotter than it should be.
I have done a few searches and found a bunch of suggestions, impeller, corrosion at the hose connection on the outdrive, exhaust manifold.....
Based on my experience with other boats I checked for leaks and found none. The connection at the outdrive looks good. So then I pulled the impeller and it looks good to me. The ones I have replaced in the past were hard and missing fins. This one is soft and looks good. Just want to get ideas on the most likely area to check next. This weekend I'm going to replace the plugs and check the timing as I know to much advance or hot plugs can add to engine heat.
Thanks
Thanks
