Greg68S
- Joined
- Feb 18, 2012
- 200
1990 Carver 2357 Montego
Volvo Penta AQ271C 5.7 V8
Duo Prop
Engine back fires at 2800 to 3000 rpm's. Boat will not climb above 3000 rpm. Just pops and fouls a plug or two each time. But then will idle perfectly at 650 to 700 rpms New wires, plugs, distributor cap & rotor, holly carb equipt w/fresh rebuild. Timing set at 6 degrees per volvo manual. Idles perfectly at 650 to 700 rpm's. What bugs me is that the manual says that the number one cylinder on the cap should be in front at 6 o'clock but its actually in back at 12 o'clock. Plugs are gapped appropriately.
HELP ANYONE. Any and all is appreciated.
Duo Prop
