Volvo Penta DP-SB 2013 Steering arm have restriction when everything is disconnect
Bob999333
Hi everybody, I removed my transom and I disconnect the steering actuator inside the boat.When I move the steering arm whith my hand I feel restriction, I can move the steering arm but its difficult. I found the pre load of the bearing hard. IS IT NORMAL ??? THANKS IN ADVANCE FOR YOUR ANSWER :rolleyes::rolleyes::rolleyes:
Ayuh,...... Welcome Aboard,..... No, the drive should swing fairly easily,.....
Bob999333
Thank you !!! , just disassembly and grease it and its fine,it was just dry its a rubber sleeve :joyous::joyous::joyous:
