I have a '95 3.0 GS Volvo Penta with an SX outdrive. When I purchased the boat, I recognized a solid "thunk!" when putting the boat in forward or reverse and negotiated a decent price realizing there would be some repair costs. Just after the purchase, I found that the frond engine mount lag bolts were stripped out. After some fiberglass, resin, redrill and longer lags, that problem is fixed.
Still the "thunk!" when shifting. Last fall, I pulled the outdrive and found the gimball had a lot of fore-aft slop. Also, the u-joint was sloppy, and wet. When I purchased the boat, there was no water in the bilge. Throughout the summer, I noticed more and more bilge water.
So, for this spring, my project will be to replace the u-joint and gimball. I am also considering replacing the bellows, shift cable, and engine coupler. I have a repair manual, need an alignment tool and slide hammer.
This should be a fun project, a learning project. Any lessons learned would be helpful. I will keep you posted with updates.
