I have replied to another post and its rightly been pointed out that it not much to do with ops original post, so thought i would start a new one:joyous:
All bolts were M8x50 apart from the last two, i ground a small chunk of the end of each one so bare steel was exposed.
All additives were mixed at roughly 20ml to 100 ml sea water taken from where my boat is moored
1st pic, bolts left to right, Neutra salt, std glycol anti freeze, 100% sea water, salt away, i cant find the rest of my sticky label to tell you what the last two bolts were immersed in!
2nd pic sludge left in bottom of neutra salt jar, all other jars were pretty much spotless as was the glycol botl you can see in the bottom of the pic
The neutra salt and the salt away both ate away the bolts zinc coating over the first few days, you can see this happening in the youtube video at the bottom of this post
Certainly makes you think!
Salt Away reaction to a zinc coated mild steel bolt, neutra salt test - YouTube
Lynall
Lynall
