Volvo Penta Outdrive Fitment
POPS PLAYPEN
can anyone tell me if the 280B outdrive can be replaced with 270B or 290B or any other outdrives in the same family without much fabrication? thanks pops
Don S
Re: Volvo Penta Outdrive Fitment
In general No.
Attaching methods of the helmut to the outdrive vary between SOME 270's and 280's, the H bracket that mounts the drives to the transom shield are different on the 290's (along with the transom shield)
If you knew exactly which 270 you had, you might be able to replace the clamp ring on the upper gear box and reshim the double bearing box and gears and make it work, but you really need to know how to set up the gears to do that.
