Looking through the forums, I have not found a link to serial number identification for Volvo-Penta outdrives, just engines so I will throw out my serial number and see if the experts can help. We need to get a rebuilt upper gearbox, swap it out of our boat we keep in Alaska, then send the core back in August after our annual trip. The serial number is 3102093409. We think it's a 290DP. It was sold to us new on 2/7/90. It is a 1.95 gear ratio but after reading the forums, I don't think the upper gears determine that. The outdrive is powered by a Volvo-Penta AQAD-41B diesel engine.
The problem with the outdrive is it won't go into/is slipping out of forward gear at near idle RPM. We suspect the cones are in need of deglazing or replacement. Once under a bit more RPM, the boat does fine, she just won't idle in forward gear which makes it difficult to troll.
Any help is greatly appreciated!
Thanks!
Eric
Thanks!
Eric
