1998 Cobalt 220 purchased used, two years ago.
Drive Unit DP-SM 1.95(M22)
I am trying to remove my vertical drive unit for maintenance of the u-joints, and replacement of the bellows.
I have followed the removal instructions in the volvo penta manual. The six nuts have been removed, the shift linkage disconnected, and the pivot rod has been removed from the vertical drive.
The drive seems to be fused to the transom bracket and will not break free. I have used penetrating oil and tapped the housing with a hammer.
It will not break loose.
The drive is supported by the eye bolt screwed into the dip stick hole.
Any advise on how to break it loose??
