volvo penta sea water pump impeller
jfalco
i have a volvo penta aq211a 1988 engine and im looking to replace the raw water pump impeller, the boat is fresh water cooling but im looking for the part # for the sea water pump impeller, also im reading the manuel but it doesnt explain how to replace it, can someone explain how to replace it and what gaskets etc... i will need?
possum2082
Re: volvo penta sea water pump impeller
i just changed my first impeller a few weeks ago. take off the 4 or so brass bolts holding the raw water pump impeller cover on and take the cover off (there should be a gasket of sorts). mine was a bit stuck and i needed to use 2 small flat head screwdrivers going back and forth to pry the impeller out on either side.
the number you will need should be on the impeller. i ordered a kit (impeller and gasket) on ebay with the number for $35. it even came with a small pack of ky jelly for installation purposes, of course.
good luck.
jfalco
thanks possum thats kinda what i thought was involved i was hoping someone could give me the part # so i could get the part b-4 taking it apart
Don S
This is from Volvo service bulletin 26-6-2
attachment.php
jfalco
ok impeller kit arrived today, part #3862281, there is a picture on the impeller box that says if u have this pump do not use this impeller kit, my pump looks exactly like the picture so i took the numbers off the pump front cover and they are f5b-1 and 10-24228-1 the b in the first number may be a 8 i just cant tell, i am just double checking before disasembling, also what are the two little rubber plugs for?
