jluchuk
- Joined
- May 20, 2008
- 43
I have a Larson 290 with twin Volvo DP-SM out drives. To change the outdrive fluid you have to remove the duo props to get at the drain screw. After change the fluid and putting the props back on I was concerned about what kept the prop nuts in place since there was no castle nut with a carter pin nor a locking washer. I have since found out that Volvo uses a nylock type nut for both the inner and outer nuts. The best price I can find for these Volvo prop nuts are $30 per nut or $120 for 2 each to replace them. Does anyone know approximately how many times you can take these on and off before they are considered worn out? I am worried that the nuts went on too easy and could spin off and lose a prop.
