Volvo Prop part number
low timer
Hello, I'm looking to purchase a spare set of F5 Volvo Duo props. I have a question concerning the part number stamp on the props. The first letters are F5 followed by the part number, but what does the last two digits represent? I see several different F5 props, but the last two digits are different. Do the last two digits on both props need to match?
Thanks for the information!
Maclin
Re: Volvo Prop part number
Volvo DuoProps have a front and rear prop as a set. Each prop has a different part#. There is also a part number for the set. Each set of numbers has the first 5 numbers the same and the last 2 are different.
F5's numbers are:
3851495 for a set
3851465 for the LH rotation prop which I believe is the larger front prop.
3851475 for the RH rotation prop which I believe is the smaller rear prop.
  • Volvo_Prop_guide_2005_2006.pdf
Thalasso
Go here and you will find the prop #'s for a set or each.
www.iboats.com/Volvo-Penta-Propellers
Type F Single #3851475 Stainless Steel Boat Propeller Rear three blade----$799.50
Type F Single #3851465 Stainless Steel Front----$799.50
Type F #3851495 Stainless Both-----$1,599.00
You can now buy composit props for the F5 with replacement blades
low timer
The props on the boat now are:
F5FRONT 3851465 7G
F5REAR 3851475 7G
The props part number I looking purchase as a spare are:
F5FRONT 3851465 BH
F5REAR 3851475 BJ
The questions I have, what does the last two digits represent such as 7G, BH or BG? The last two digits match on my current props, do the last digits need to match? The props I'm looking to buy were pulled from a kit box part number 3851495.
Thanks for the help
they could be batch numbers.
Thalasso
F5FRONT 3851465 7G
F5REAR 3851475 7G
F5FRONT 3851465 BH
F5REAR 3851475 BJ
Thanks for the help
I think they need to match just like your current set up. There must be is a reason for this. What it is i don't know. I don't think you can mix them. (Ex) 7G, with a BH or BG
They should work. As long as they are the same material. I think some of those codes depict weather there stainless, aluminum or what ever.
SKU:#3851495
Manufacturer: Volvo Penta
Brand: DuoProp - Type F
Material: Stainless Steel
Size Code: F5
Blades: Front 3 : Rear 3
Rotation: DuoProp Dual
Maclin
When I said "they do not need to match" I meant the two characters after the full part# from the examples given of "7G" or "BG" or "BH", those are immaterial, pun intended.
The F series is all stainless steel. The equivalent aluminum D series. The "7G" and "BG" and "BH" have nothing to do with material or size or pitch. The F5 props you have your eye on is a matched set.
low timer
Good, I was concerned the last two digits had to match.
Thanks for the help!
