unless you are converting to a Bravo Drive (which has the crank driven raw water pump), no need to add a crank driven pump to an alpha installation. the water flow helps cool the drive.
if you are trying to get around the annual maintenance, you still need to pull the drive every year to inspect the alignment, bellows, gimble and u-joints.
