Volvo SX-M drive trailing position
Tail_Gunner
I dont seem to have a trailing position for the out drive..That is i can trim the drive out for trailing but there is no switching like a merc to put here way up...Is this the way it is or am i missing something..:confused:
Re: Volvo SX-M drive trailing position
Ayuh,... For those of Us who've by-passed/ deleted their trim limit switches,+ gauge indicators,....
We experince the same thing on a Merc... Up is Up til the end,...
Donno how Volvo does it..
Gary H NC
My old boat with a Cobra drive was like that.One button just up and down.
Nothing marked trailer position or anything.
Don S
The SX drives never had trim limit as standard, only the DP-S drives. It would work off the same sender as the gauge sender, only more wiring and the dreaded "Black Box" full of circuits and flashing LED's and calibrations and .............. What a mess those things are.
Why, you want one ??????
rodbolt
ohhh the black box and LED's. nightmares.
most the SX drives had only a single switch and it ran up or down until it cannot.
trust me, you dont want the black box.
BeaufortTJustice
My SX-A only has one switch for trim/tilt... to trailer, I just keep pushing it up until the sound changes, then release it.
Tail_Gunner
:redface: Well bought a new house with a sharp angled up hill drive way and i cannot get her up the mountain i guess thats what i call the drive way...without dragging the drive..:mad:
Now my little alpha just trim it up and trim up the trailer switch and its up and away...Geeshh fianlly found a flaw with the volvo drive..:mad:
Fun Times
Might be time for thicker trailer bunks, Or get a lower truck receiver/Trailer Ball set up if you can go a little lower with it safely.
Do you have a swim step mounted to the boat in any way over the drive, Because if you do then maybe someone had to put trim limit spacers in the rams to keep the drive from going all the way up to keep the drive from hitting anything above it, Just a few thoughts with out being able to see you're set up.:)
mcleaves
With my SX trimmed all the way up I have 6"-8" in height from the garboard drain to the lowest point on the drive of the drive. I'd wipe out my keel before the drive could hit the ground.
If it DID hit the ground it'd be the bullet taking a beating. If you are hitting the skeg something is wrong with the trim as it' not coming up enough.
Robbabob
No Extra button like on Merc's to get you there. Just keep trimming up until you hear the noise change.
Safe thing with the Merc's is that when you want to ONLY trim all the way up, you don't have to be too careful about over trimming outta da water.
Good luck and happy boating! :cool:
