billkoller
- Joined
- Mar 13, 2017
- 9
1995 Volvo 5.8 EFI, New Raw Water Pump. Boat is in the water and the Gimbal water inlet is below the waterline by about 2". I placed a clear hose from the Pump out to the Vaporizer to check water flow at low RPM's the line is full of water at 1700 RPM and avoce there is more air in line than water. I took off the line from the Gimbal to the pump and pressure tested it, it passed, I replaced the Raw water pump and still have same results. There is no water at the Gimbal water inlet, with that much air I would assume I would see water if it were cracked.
Is it possible my exhaust is filling the water jacket of the outdrive causing it to sucking in as the pump starts moving at higher speeds?
Tomorrow I will be swapping the input hose from Gimbal to pump from one engine to the other. If that does not change I plan on adding running a long hose from the other motors Gimbal to this motor and vice versa to see how each motor reacts.
if anyone has any other ideas please let me know, I'm at a total loss.
