volvo to mercruiser
hudman
if a boat origionally had a volvo outdrive, is it possible to recut the transom for a mercruiser? Ive found a hull ,,, 71 model, that had a volvo unit it it but all is now gone and id rather rebuild it as a merc? is this possible without gelcoat/fiberglass work?
Re: volvo to mercruiser
I saw an Adapter that would Do That,....<br />But,.. Only Once,+ I don't know Where they got it.........<br /><br />Why not just Glass it In,....... It Ain't that big of a Job,......<br />Compared to the task you're looking at Anyway.....
JIm Cook
Maybe Mercruiser part no. 827691A1.<br />Adapter plate for Volvo to Merc.
DHPMARINE
Jim ,That's an interesting part number.It comes up as a 'template kit-trans' for just under $1000. Do you know more about it ?<br /><br />DHP
JIm Cook
I found it at mercurypartsexpress.com<br />It's listed under "engine accessories" as<br />a "transom adapter plate" and has a small<br />picture of the part. That's all I know about<br />it other than it sure is pricy!
Don S
Found this on the Mercruser Parts Express site.<br /><br />
<br />For use when replacing a Volvo or BMW sterndrive with a new standard MCM Alpha or Bravo sterndrive. It provides a rugged mounting that seals the competitors" larger transom cutouts and eliminates costly rework to fiberglass, aluminum, or steel transoms.
