. Volvo penta 3863191 very thin tin like metal gasket with a black coating and a ridges. It is not a dry joint exhaust.Cannot say with 100 percent certainty, but have been using Merc gaskets on Barr and others but these are also the fiber type.
Which gasket are you calling metal, are they for dry joint exhaust?
I ended up using fiber, worked well
Kccoe reply : I think I am going with fiber ones after I researched further on the Volvo penta gaskets . The Volvo gaskets require very precise procedures and the installation instruction contradict themselves . The instructions state not to use any sealant with the Volvo gaskets and then other Volvo instructions state you need use a high temp copper sealant with the gaskets. The Volvo manual states torque the riser bolts to 12 to 13 ft-lb and the gasket instruction states torque riser bolts to to 26 ft -lb . A big difference
http://forums.I **********/forum/engi...8-frankenmotor
The fiber type gasket provide more room for error. The error I mention is if the surfaces are not perfectly flat. The Barr manifolds in most cases are not made to the same precise standards used by Volvo. Keep in mind I am not a Volvo guy just offering thoughts on the issue. If it was me I would use either the Barr of Merc fiber gaskets and also take a flat file across the two surfaces to see if it is flat.
